Ana içeriğe geç
Lenovo IdeaPad S10-2 Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Lenovo IdeaPad S10-2 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Start with laptop closed.
    • Turn laptop over so the back panel is visible, as shown in the second image.
    • Remove the two 40 mm Phillips screws using a Phillips J0 head screwdriver.
  2. Lenovo IdeaPad S10-2 Hard Drive Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad S10-2 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Remove both 40 mm Phillips screws using a Phillips J0 head screwdriver.
    • Remove the back panel and set it aside.
  3. Lenovo IdeaPad S10-2 Hard Drive Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad S10-2 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Remove the 40 mm screw using a Phillips J0 head screwdriver.
  4. Lenovo IdeaPad S10-2 Hard Drive Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad S10-2 Hard Drive Replacement: adım 4, 2 resimden 2.
    • After removing the screw, carefully wedge the flat end of a spudger in the spacing to remove the hard drive from the port.
    • Pry the hard drive out of its port.
    • Push the wedged end of the spudger out as indicated by the action shots.
  5. Lenovo IdeaPad S10-2 Hard Drive Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad S10-2 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Carefully lift the hard drive enclosure to remove it from the laptop.
    • The enclosure is the metal case holding the actual hard drive. You must remove the metal case in order to replace the hard drive.
  6. Lenovo IdeaPad S10-2 Hard Drive Replacement: adım 6, 3 resimden 1. Lenovo IdeaPad S10-2 Hard Drive Replacement: adım 6, 3 resimden 2. Lenovo IdeaPad S10-2 Hard Drive Replacement: adım 6, 3 resimden 3.
    • The hard drive enclosure has four 40 mm screws keeping the hard drive in place.
    • Remove the four 40 mm screws with a Phillips J0 head screwdriver.
  7. Lenovo IdeaPad S10-2 Hard Drive Replacement: adım 7, 2 resimden 1. Lenovo IdeaPad S10-2 Hard Drive Replacement: adım 7, 2 resimden 2.
    • Slide the hard drive out of the enclosure.
    • The new hard drive can be inserted into the same enclosure.
Sonuç
Anthony
258 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 9,500
