Ana içeriğe geç
Lenovo IdeaPad S10-2 Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad S10-2 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Rotate the laptop so the back side is facing you.
    • From this side, you should be able to see both of the gaps where the two plastic materials meet.
  2. Lenovo IdeaPad S10-2 Keyboard Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad S10-2 Keyboard Replacement: adım 2, 2 resimden 2.
    • Wedge the nylon or metal spudger inside the gap and pry open the two plastic parts.
  3. Lenovo IdeaPad S10-2 Keyboard Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad S10-2 Keyboard Replacement: adım 3, 2 resimden 2.
    • Open the laptop.
    • Place the nylon or metal spudger under the top half that is loose and pull up to pry it open.
  4. Lenovo IdeaPad S10-2 Keyboard Replacement: adım 4, 3 resimden 1. Lenovo IdeaPad S10-2 Keyboard Replacement: adım 4, 3 resimden 2. Lenovo IdeaPad S10-2 Keyboard Replacement: adım 4, 3 resimden 3.
    • Pull up on the loose component to remove.
    • As you lift the keyboard, you should be able to see a strip connected to the laptop.
  5. Lenovo IdeaPad S10-2 Keyboard Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad S10-2 Keyboard Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad S10-2 Keyboard Replacement: adım 5, 3 resimden 3.
    • Remove the strip by pulling both sides of the blue strip out.
    • Lift and remove the keyboard from the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mary
132 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 3,261
