Ana içeriğe geç
Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement, Wireless WiFi Card: adım 1, 1 resimden 1.
    • The tools needed are the blunt edge of the spudger and a Phillips J0 head screwdriver.
    • Ensure your device is powered off before continuing.
  2. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: adım 2, 2 resimden 2.
    • Turn the laptop over to begin.
    • Remove the two 40 mm screws with a Phillips J0 head screwdriver.
  3. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: adım 3, 2 resimden 2.
    • The WiFi card is found near the bottom of the panel.
  4. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: adım 4, 3 resimden 1. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: adım 4, 3 resimden 2. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Do not use the metal precision tweezers as shown.
    • Using the blunt end of the spudger, wedge the spudger beneath the connector and pull straight up to remove the white wire. Repeat to remove the black connector.
    • When reinstalling these U.FL connectors, hold the connector in place and gently push down. The connector should snap into place like a button.
  5. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: adım 5, 3 resimden 3.
    • Remove the two 40 mm screws using a Phillips J0 head screwdriver.
    • Lift and remove the WiFi card.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lucy Mendez
152 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 2,149
