Ana içeriğe geç
Lenovo IdeaPad S210 Touch Cooling Fan Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad S210 Touch Cooling Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Cooling Fan Replacement, Back Panel: adım 3, 2 resimden 1. Lenovo IdeaPad S210 Touch Cooling Fan Replacement, Back Panel: adım 3, 2 resimden 2.
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: adım 4, 1 resimden 1.
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: adım 5, 3 resimden 3.
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
  6. Lenovo IdeaPad S210 Touch Cooling Fan Replacement, Cooling Fan: adım 6, 1 resimden 1.
    • Many of the wire connections to the motherboard are secured by tape for vibration protection. Your device may or may not have this tape.
    • If any tape is present, remove all tape from the area within the red area.
  7. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: adım 7, 2 resimden 1. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: adım 7, 2 resimden 2.
    • Using a #0 Phillips screwdriver, unscrew the four 3mm captive screws securing the copper tube onto the motherboard.
    • These captive screws are secured by plastic washer to the copper tube and will remain in the heat sink assembly during removal.
  8. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: adım 8, 3 resimden 1. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: adım 8, 3 resimden 2. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: adım 8, 3 resimden 3.
    • Remove the tape connecting the copper tubing to the cooling fan.
    • Lift and remove the heat sink assembly.
  9. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: adım 9, 1 resimden 1.
    • Using a #0 Phillips screwdriver, remove the three 3mm screws around the perimeter of the fan.
  10. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: adım 10, 2 resimden 1. Lenovo IdeaPad S210 Touch Cooling Fan Replacement: adım 10, 2 resimden 2.
    • Remove the wiring from the motherboard by gently pulling the wire connector at the base of the wires.
    • Once the wires are removed, the cooling fan assembly is disconnected. You may now remove the cooling fan.
Sonuç
Zack Colman
885 İtibar
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 12
Her zaman: 628
