Ana içeriğe geç
Lenovo IdeaPad S210 Touch Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure your device is unplugged and shut down.
    • Place the laptop down with the cooling vents facing upwards.
  2. Lenovo IdeaPad S210 Touch Hard Drive Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad S210 Touch Hard Drive Replacement: adım 2, 2 resimden 2.
    • Use your finger to slide the latch towards the unlocked position (away from the other latch). If done correctly you will see red.
    • Slide the second latch to the unlocked position while gently pulling the battery away from the laptop.
  3. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Back Panel: adım 3, 2 resimden 1. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Back Panel: adım 3, 2 resimden 2.
    • Using the #0 Phillips screwdriver, remove the nine 4mm screws on the back panel.
  4. Lenovo IdeaPad S210 Touch Hard Drive Replacement: adım 4, 1 resimden 1.
    • Gently pull the two rubber feet closest to battery away from the device. Using a #0 Phillips screwdriver, remove the 5mm screw under each rubber foot.
  5. Lenovo IdeaPad S210 Touch Hard Drive Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad S210 Touch Hard Drive Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad S210 Touch Hard Drive Replacement: adım 5, 3 resimden 3.
    • Slowly begin working your plastic opening tool along the panel to undo the latches around the laptop.
  6. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 1. Lenovo IdeaPad S210 Touch Hard Drive Replacement, Hard Drive: adım 6, 2 resimden 2.
    • Using a #0 Phillips screwdriver, remove the four 4mm screws that secure the hard drive bracket to the motherboard.
  7. Lenovo IdeaPad S210 Touch Hard Drive Replacement: adım 7, 2 resimden 1. Lenovo IdeaPad S210 Touch Hard Drive Replacement: adım 7, 2 resimden 2.
    • Slide your hard drive away from your motherboard until fully removed.
    • Be careful not to snag any wires routed along the battery side of the hard drive.
  8. Lenovo IdeaPad S210 Touch Hard Drive Replacement: adım 8, 3 resimden 1. Lenovo IdeaPad S210 Touch Hard Drive Replacement: adım 8, 3 resimden 2. Lenovo IdeaPad S210 Touch Hard Drive Replacement: adım 8, 3 resimden 3.
    • This step is only necessary if you are swapping your old hard drive for a new one.
    • Using a Phillips #0 screwdriver, remove four 2.5mm screws, two per side, to release the hard drive from its mounting bracket. These screws are directly next to each mounting screw you removed previously.
    • Install the mounting brackets onto the new hard drive during reassembly.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Zack Colman
885 İtibar
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,400
