Neye ihtiyacın var
Power off the laptop and place it face-down on a non-scratching surface.
Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
Disconnect the battery cable by gently pulling it straight out of the connector.
Remove the battery from the laptop.
Remove the two 3 mm screws connecting the fan to the casing using a Phillips #0 screwdriver.
Carefully unwind the black cable that runs between the top of the battery and the bottom of the fan from the grooves along the side of the fan.
In order to do so, you will need to pull up the metallic tape that holds the cable in place using either your fingers or a plastic prying tool to lift up the edge.
Unplug the wire connecting the speakers to the motherboard.
Remove the speakers from each side of the laptop.
Remove the four 3 mm screws holding the hard drive expansion slot in place using a Phillips #0 screwdriver.
Remove the three 3 mm screws that secure the black heat sink near the top of the computer using a Phillips #0 screwdriver.
Lift the heat sink vertically to remove it from the laptop.
Using an opening tool, carefully flip up the retaining flaps holding the silver video cable in place.
Slide the ribbon cable out of each connector.
Pull up the black foam adhesive that covers the screw and connectors holding the Wi-Fi card in place.
Using an opening tool, flip up the retaining flap that holds the connector to the thin black ribbon cable at the bottom of the motherboard.
Gently remove the ribbon cable from its connector.
The cable is folded over and connected to itself with an adhesive. Be careful to only pull at the top fold of the cable.
3 farklı kişi bu kılavuzu tamamladı.
