Ana içeriğe geç
Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: adım 1, 2 resimden 2.
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: adım 2, 1 resimden 1.
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: adım 3, 2 resimden 1. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: adım 3, 2 resimden 2.
    • Pull up the black foam adhesive that covers the screw and connectors holding the Wi-Fi card in place.
  4. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: adım 4, 2 resimden 2.
    • Using an opening tool, lift up on the black and white coaxial cables on the Wi-Fi card and gently pull upward to unplug them.
    • When reconnecting the cables, be sure to match the colors to the arrows on the Wi-Fi card.
  5. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: adım 5, 2 resimden 2.
    • Remove the single 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Gently lift the Wi-Fi card out of the computer.
Sonuç
Kristen Gismondi
82.722 İtibar
202 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.432 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 29
Son 30 gün: 59
Her zaman: 1,073
