Ana içeriğe geç
Lenovo IdeaPad S400 Touch Fan Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad S400 Touch Fan Replacement, Battery: adım 1, 3 resimden 1. Lenovo IdeaPad S400 Touch Fan Replacement, Battery: adım 1, 3 resimden 2. Lenovo IdeaPad S400 Touch Fan Replacement, Battery: adım 1, 3 resimden 3.
    • Turn your computer over so the back is face up.
    • Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
    • The battery cover will then pop up allowing you access to the battery.
  2. Lenovo IdeaPad S400 Touch Fan Replacement, Fan: adım 2, 3 resimden 1. Lenovo IdeaPad S400 Touch Fan Replacement, Fan: adım 2, 3 resimden 2. Lenovo IdeaPad S400 Touch Fan Replacement, Fan: adım 2, 3 resimden 3.
    • Remove the five 6mm Phillips #0 screws from the back panel.
    • Pull back the rubber tabs from the corners of the laptop backing to expose the screws.
    • The two tabs next to the battery flip toward the battery. The two remaining tabs flip down, away from the battery.
    • Remove the four 4mm Phillips #0 screws that are underneath the rubber tabs.
    • Remove the three 6mm Phillips #0 screws from under the battery.
  3. Lenovo IdeaPad S400 Touch Fan Replacement: adım 3, 1 resimden 1.
    • Slide the back panel away to remove it.
    • Don't be afraid to apply force when removing the back panel.
  4. Lenovo IdeaPad S400 Touch Fan Replacement: adım 4, 1 resimden 1.
    • Remove the two 5mm Phillips #0 screws holding the fan down.
  5. Lenovo IdeaPad S400 Touch Fan Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad S400 Touch Fan Replacement: adım 5, 2 resimden 2.
    • Unplug the fan's power supply cord.
  6. Lenovo IdeaPad S400 Touch Fan Replacement: adım 6, 1 resimden 1.
    • Pull the fan out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 425
