Ana içeriğe geç
Lenovo IdeaPad U310 Ram Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad U310 Ram  Replacement, RAM: adım 1, 1 resimden 1.
    • Make sure device is turned off and disconnected from any power source before proceeding.
    • Flip the device over so the bottom panel is facing up.
    • Remove the rubber feet by pinching and pulling in an upward motion.
    • The rubber feet are missing from this photo, but will be located within the red markups.
  2. Lenovo IdeaPad U310 Ram  Replacement: adım 2, 1 resimden 1.
    • Remove the 4 screws securing the bottom panel to the device.
    • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
  3. Lenovo IdeaPad U310 Ram  Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad U310 Ram  Replacement: adım 3, 2 resimden 2.
    • Place the plastic opening tool between the bottom panel and device.
    • Pry around the device's outer edge until the bottom panel is no longer attached.
    • Lift the bottom panel up and away from device.
  4. Lenovo IdeaPad U310 Ram  Replacement: adım 4, 1 resimden 1.
    • Pry the RAM's two holding clips in an outward motion.
  5. Lenovo IdeaPad U310 Ram  Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad U310 Ram  Replacement: adım 5, 2 resimden 2.
    • Continue to pry open the clips, and slip the RAM from its housing.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 21
Her zaman: 2,526
