Ana içeriğe geç
Lenovo IdeaPad U350 Hard Drive Replacement
Neye ihtiyacın var
    1. Lenovo IdeaPad U350 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
      • Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
      • These screws are attached to the panel. When unscrewing, be sure to stop when you here a click.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo IdeaPad U350 Hard Drive Replacement: adım 2, 1 resimden 1.
      • Lift the back panel from the side closest to the battery and remove the panel.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo IdeaPad U350 Hard Drive Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad U350 Hard Drive Replacement: adım 3, 2 resimden 2.
      • Slide the hard drive to the right, away from the RAM modules.
      • Lift the hard drive from the side closest to the RAM modules.
      • When re-inserting the hard drive, ensure that the copper contacts on the drive's connector are facing upwards.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
James Morizzo
499 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Hickman Fall 2014 USF Tampa, Team 1-4, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G4
3 Üyeler
45 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 37
Her zaman: 2,169
