Ana içeriğe geç
Lenovo IdeaPad U350 RAM Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad U350 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Unscrew the six screws on the back panel of the laptop using a PH1 Phillips bit.
    • These screws are 4.7mm long with a head diameter of 3.68mm.
    • The screws are attached to the panel. When unscrewing be sure to stop when you hear a click.
    FixBot'a Sor
    Yorum Ekle
  2. Lenovo IdeaPad U350 RAM Replacement: adım 2, 1 resimden 1.
    • Gently lift the back panel from the side closest to the battery and remove panel
    FixBot'a Sor
    Yorum Ekle
  3. Lenovo IdeaPad U350 RAM Replacement: adım 3, 1 resimden 1.
    • Push retention clips outward and then gently slide out of slot
    FixBot'a Sor
    Yorum Ekle
  4. Lenovo IdeaPad U350 RAM Replacement: adım 4, 1 resimden 1.
    • Remove white and black wires to make room to remove the second RAM module.
    FixBot'a Sor
    Yorum Ekle
  5. Lenovo IdeaPad U350 RAM Replacement: adım 5, 1 resimden 1.
    • Just like RAM Module 1, push retention clips outward and gently slide out the RAM Module.
    • When re-installing RAM modules, be sure to insert them at a 45 degree angle. This is the same angle that they should pop up to after the retention clips are pushed outward.
    FixBot'a Sor
    Yorum Ekle
Sonuç
James Morizzo
499 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-4, Hickman Fall 2014 USF Tampa, Team 1-4, Hickman Fall 2014 üyesi
USFT-HICKMAN-F14S1G4
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 1,316
