Ana içeriğe geç
Lenovo IdeaPad U410 Battery Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad U410 Battery Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo IdeaPad U410 Battery Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Lenovo IdeaPad U410 Battery Replacement: adım 2, 3 resimden 1. Lenovo IdeaPad U410 Battery Replacement: adım 2, 3 resimden 2. Lenovo IdeaPad U410 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
  3. Lenovo IdeaPad U410 Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Make sure your computer is turned off.
    • Lift the back panel away from you.
    • Locate the battery in the bottom right corner.
  4. Lenovo IdeaPad U410 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the three 3mm screws located on the perimeter of the battery using the Phillips #1 screwdriver.
  5. Lenovo IdeaPad U410 Battery Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad U410 Battery Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad U410 Battery Replacement: adım 5, 3 resimden 3.
    • Locate the small rectangle shaped connector to the left of your battery.
    • Use your fingers to gently detach the white connector.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 831
