Ana içeriğe geç
Lenovo IdeaPad U410 Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad U410 Hard Drive Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo IdeaPad U410 Hard Drive Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Lenovo IdeaPad U410 Hard Drive Replacement: adım 2, 3 resimden 1. Lenovo IdeaPad U410 Hard Drive Replacement: adım 2, 3 resimden 2. Lenovo IdeaPad U410 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
  3. Lenovo IdeaPad U410 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Locate the hard drive in the bottom left corner.
  4. Lenovo IdeaPad U410 Hard Drive Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad U410 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the three 3mm screws located on the rim of the hard drive.
  5. Lenovo IdeaPad U410 Hard Drive Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad U410 Hard Drive Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad U410 Hard Drive Replacement: adım 5, 3 resimden 3.
    • Use your fingers to detach the black connector from the hard drive.
  6. Lenovo IdeaPad U410 Hard Drive Replacement: adım 6, 2 resimden 1. Lenovo IdeaPad U410 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Unscrew the four screws on either side of the hard drive with the Phillips #1 screwdriver.
  7. Lenovo IdeaPad U410 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Use your fingers and gently lift the hard drive from the case it was screwed into.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 1,107
