Ana içeriğe geç
Lenovo IdeaPad U410 Screen Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad U410 Screen Replacement, Screen: adım 1, 2 resimden 1. Lenovo IdeaPad U410 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Make sure your laptop is turned off before disassembling.
    • Power off the laptop.
    • Using the metal spudger, gently pry off the black trim around the screen.
    • Metal spudger can be used, but using your hand will prevent the screen and the plastic border from any damage.
  2. Lenovo IdeaPad U410 Screen Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad U410 Screen Replacement: adım 2, 2 resimden 2.
    • Remove the six 3 mm Phillips #1 screws holding the screen to the laptop.
    • Ignore the "Do not touch" label on the bottom portion of the screen. It will not damage the laptop.
  3. Lenovo IdeaPad U410 Screen Replacement: adım 3, 3 resimden 1. Lenovo IdeaPad U410 Screen Replacement: adım 3, 3 resimden 2. Lenovo IdeaPad U410 Screen Replacement: adım 3, 3 resimden 3.
    • Lower LCD screen onto the keyboard.
    • Find the gold connector on the bottom of the LCD panel.
    • Gently grab the connector on both sides and pull the connector straight out.
    • Connector cable is very fragile. Use the least amount of force possible.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Edric An
433 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 1,481
