Ana içeriğe geç
Lenovo IdeaPad U410 Solid State Drive Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad U410 Solid State Drive  Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo IdeaPad U410 Solid State Drive  Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Lenovo IdeaPad U410 Solid State Drive  Replacement: adım 2, 3 resimden 1. Lenovo IdeaPad U410 Solid State Drive  Replacement: adım 2, 3 resimden 2. Lenovo IdeaPad U410 Solid State Drive  Replacement: adım 2, 3 resimden 3.
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
  3. Lenovo IdeaPad U410 Solid State Drive  Replacement, Solid State Drive: adım 3, 3 resimden 1. Lenovo IdeaPad U410 Solid State Drive  Replacement, Solid State Drive: adım 3, 3 resimden 2. Lenovo IdeaPad U410 Solid State Drive  Replacement, Solid State Drive: adım 3, 3 resimden 3.
    • Make sure your laptop is powered off.
    • Use a Phillips #1 screwdriver to remove the 3 mm screw holding the SSD in place.
  4. Lenovo IdeaPad U410 Solid State Drive  Replacement: adım 4, 1 resimden 1.
    • Grab the SSD and pull it out from the mSATA slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Edric An
433 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 688
