Ana içeriğe geç
Lenovo IdeaPad U430 Touch Bottom Cover Removal
Neye ihtiyacın var
  1. Lenovo IdeaPad U430 Touch Bottom Cover Removal, Bottom Cover: adım 1, 1 resimden 1.
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Bottom Cover Removal: adım 3, 2 resimden 1. Lenovo IdeaPad U430 Touch Bottom Cover Removal: adım 3, 2 resimden 2.
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
Sonuç
Patrick Ripkey
627 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G6, Nance Spring 2017 USF Tampa, Team S2-G6, Nance Spring 2017 üyesi
USFT-NANCE-S17S2G6
3 Üyeler
15 adet Kılavuz yazıldı
Bir Yorum
When removing the cover, be careful: There are a few (two or three?) plastic hooks that break easily in the area around the ports and the SD slot. (It's no big deal if they do break, but you can avoid it.)
Tom Janson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 2,939
