Ana içeriğe geç
Lenovo IdeaPad U430 Touch Memory Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad U430 Touch Memory Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Memory Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad U430 Touch Memory Replacement: adım 3, 2 resimden 2.
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Memory Replacement, Memory: adım 4, 2 resimden 1. Lenovo IdeaPad U430 Touch Memory Replacement, Memory: adım 4, 2 resimden 2.
    • Press down and out on the topside of the clips holding the memory in place.
  4. Lenovo IdeaPad U430 Touch Memory Replacement: adım 5, 1 resimden 1.
    • Once the clips are free, pull the topside of the memory up, and then remove it from the slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Patrick Ripkey
627 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G6, Nance Spring 2017 USF Tampa, Team S2-G6, Nance Spring 2017 üyesi
USFT-NANCE-S17S2G6
3 Üyeler
15 adet Kılavuz yazıldı
Bir Yorum
What is the maximum RAM this machine will support?
Tom Steger - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 2,087
