Ana içeriğe geç
Lenovo IdeaPad U450 Fan Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad U450 Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off and unplug your laptop to prevent the risk of electrocution.
    • Turn your laptop over so that the bottom is face up.
  2. Lenovo IdeaPad U450 Fan Replacement: adım 2, 1 resimden 1.
    • On the top left of the laptop there is a switch. Make sure it's pushed in the unlocked position.
  3. Lenovo IdeaPad U450 Fan Replacement: adım 3, 1 resimden 1.
    • Locate the switch collinear with the last one and move the switch to an unlocked position.
  4. Lenovo IdeaPad U450 Fan Replacement: adım 4, 1 resimden 1.
    • Remove the unlocked battery.
  5. Lenovo IdeaPad U450 Fan Replacement, Top Panel: adım 5, 1 resimden 1.
    • Turn the laptop over so that the bottom is facing up.
  6. Lenovo IdeaPad U450 Fan Replacement: adım 6, 1 resimden 1.
    • Remove all 7mm phillips head screws using the Phillips #00 screwdriver.
  7. Lenovo IdeaPad U450 Fan Replacement: adım 7, 1 resimden 1.
    • Turn the laptop over again and open the laptop.
  8. Lenovo IdeaPad U450 Fan Replacement: adım 8, 1 resimden 1.
    • Gently lift up the top panel utilizing the hole where the battery would be.
    • Keyboard ribbon cable is still connected. Flip the ZIF connector up and remove the ribbon cable.
  9. Lenovo IdeaPad U450 Fan Replacement: adım 9, 1 resimden 1.
    • Disconnect any wires that are connected to the top panel from the bottom of the laptop.
  10. Lenovo IdeaPad U450 Fan Replacement, Fan: adım 10, 1 resimden 1.
    • Unplug the bundled fan connector from the motherboard.
  11. Lenovo IdeaPad U450 Fan Replacement: adım 11, 1 resimden 1.
    • Unscrew all screws that hold the fan down using the Phillips #00 screwdriver.
  12. Lenovo IdeaPad U450 Fan Replacement: adım 12, 1 resimden 1.
    • Remove the fan from the slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Anna Church
146 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S7-G1, Julie Spring 2017 UMass Dartmouth, Team S7-G1, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S7G1
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 8
Her zaman: 401
