Ana içeriğe geç
Lenovo IdeaPad U450 Screen Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad U450 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off and unplug your laptop to prevent the risk of electrocution.
    • Turn your laptop over so that the bottom is face up.
  2. Lenovo IdeaPad U450 Screen Replacement: adım 2, 1 resimden 1.
    • On the top left of the laptop there is a switch. Make sure it's pushed in the unlocked position.
  3. Lenovo IdeaPad U450 Screen Replacement: adım 3, 1 resimden 1.
    • Locate the switch collinear with the last one and move the switch to an unlocked position.
  4. Lenovo IdeaPad U450 Screen Replacement: adım 4, 1 resimden 1.
    • Remove the unlocked battery.
  5. Lenovo IdeaPad U450 Screen Replacement, Screen: adım 5, 1 resimden 1.
    • Open the laptop.
  6. Lenovo IdeaPad U450 Screen Replacement: adım 6, 1 resimden 1.
    • Remove the four 7mm phillips head screws in the corners of the screen with a Phillips #00 Screwdriver.
  7. Lenovo IdeaPad U450 Screen Replacement: adım 7, 1 resimden 1.
    • Pry the screen out of the tabs with a spudger.
  8. Lenovo IdeaPad U450 Screen Replacement: adım 8, 1 resimden 1.
    • Remove the four 7mm phillips head screws located beneath the screen.
  9. Lenovo IdeaPad U450 Screen Replacement: adım 9, 1 resimden 1.
    • Pop out the connector that links the screen to the motherboard.
  10. Lenovo IdeaPad U450 Screen Replacement: adım 10, 1 resimden 1.
    • Pop the new screen into the connector.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rachel L Rodrigues
464 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S7-G1, Julie Spring 2017 UMass Dartmouth, Team S7-G1, Julie Spring 2017 üyesi
UMASSD-JULIE-S17S7G1
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 225
