Ana içeriğe geç
Lenovo IdeaPad U530 Touch Fan Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad U530 Touch Fan Replacement, Battery: adım 1, 3 resimden 1. Lenovo IdeaPad U530 Touch Fan Replacement, Battery: adım 1, 3 resimden 2. Lenovo IdeaPad U530 Touch Fan Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the back panel by removing all screws. Use a PH000 screwdriver head.
    • Make sure to also remove the hinge screws.
  2. Lenovo IdeaPad U530 Touch Fan Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad U530 Touch Fan Replacement: adım 2, 2 resimden 2.
    • To remove the panel, use a plastic opening tool to prevent any damage.
  3. Lenovo IdeaPad U530 Touch Fan Replacement: adım 3, 1 resimden 1.
    • Locate and assess the battery. Pictured in the upper right area of the computer.
  4. Lenovo IdeaPad U530 Touch Fan Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad U530 Touch Fan Replacement: adım 4, 2 resimden 2.
    • Locate and remove all screws attaching the battery to the hull of the computer. It is recommended that you use a JIS #1 screwdriver head for this task.
    • Be careful to keep track of all removed screws.
  5. Lenovo IdeaPad U530 Touch Fan Replacement: adım 5, 1 resimden 1.
    • Detach the connection from the battery to the motherboard. This is the only connection that needs to be disconnected for the battery.
    • To remove the connection, please pull firmly, as it well secured.
  6. Lenovo IdeaPad U530 Touch Fan Replacement: adım 6, 1 resimden 1.
    • Simply lift the battery out of the computer, and acquire a replacement.
  7. Lenovo IdeaPad U530 Touch Fan Replacement, Fan: adım 7, 3 resimden 1. Lenovo IdeaPad U530 Touch Fan Replacement, Fan: adım 7, 3 resimden 2. Lenovo IdeaPad U530 Touch Fan Replacement, Fan: adım 7, 3 resimden 3.
    • Remove the six 3 mm screws from the fan using a JIS #1 screwdriver.
  8. Lenovo IdeaPad U530 Touch Fan Replacement: adım 8, 2 resimden 1. Lenovo IdeaPad U530 Touch Fan Replacement: adım 8, 2 resimden 2.
    • Disconnect the connecter cords from the fan and remove the fan.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 16
Her zaman: 305
