Ana içeriğe geç
Lenovo IdeaPad Y400 Back Panel Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Y400 Back Panel Replacement, Battery: adım 1, 3 resimden 1. Lenovo IdeaPad Y400 Back Panel Replacement, Battery: adım 1, 3 resimden 2. Lenovo IdeaPad Y400 Back Panel Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the laptop is upside down, then turn the laptop so that the battery is facing you. Now that the battery is facing you, there will be two locks, one on the left and one on the right.
    • Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red.
  2. Lenovo IdeaPad Y400 Back Panel Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Y400 Back Panel Replacement: adım 2, 2 resimden 2.
    • Unlike the first lock, the left lock does not stay in place. You will need to hold it in place as you take the battery out.
    • Slide the second (left) lock to the left and hold it there.
  3. Lenovo IdeaPad Y400 Back Panel Replacement: adım 3, 1 resimden 1.
    • Gently pull the battery out.
  4. Lenovo IdeaPad Y400 Back Panel Replacement, Back Panel: adım 4, 1 resimden 1.
    • Remove the eight 9mm screws with a Phillips #0 screwdriver.
  5. Lenovo IdeaPad Y400 Back Panel Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad Y400 Back Panel Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad Y400 Back Panel Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to remove the back panel from the device.
    • Do not force the back off, as you may break the clips keeping it down.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 373
