Ana içeriğe geç
Lenovo IdeaPad Y410p Hard Drive Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Y410p Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Hard Drive Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Y410p Hard Drive Replacement: adım 2, 2 resimden 2.
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Hard Drive Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad Y410p Hard Drive Replacement: adım 3, 2 resimden 2.
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 1. Lenovo IdeaPad Y410p Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 2. Lenovo IdeaPad Y410p Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the eight 8mm screws that fasten the bottom cover.
    • Lift bottom cover off using a metal spudger and set it aside.
  5. Lenovo IdeaPad Y410p Hard Drive Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad Y410p Hard Drive Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad Y410p Hard Drive Replacement: adım 5, 3 resimden 3.
    • If you intend to reuse this hard drive, be careful removing it as hard impacts may damage the device.
    • Using the Phillips #0 screwdriver, remove the two 3mm screws at the end of the hard drive bracket.
    • Slide the hard drive out of its seat.
Sonuç
Nick Torres
580 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 839
