Ana içeriğe geç
Lenovo IdeaPad Y410p Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Y410p Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Keyboard Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Y410p Keyboard Replacement: adım 2, 2 resimden 2.
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Keyboard Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad Y410p Keyboard Replacement: adım 3, 2 resimden 2.
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Keyboard Replacement, Keyboard: adım 4, 2 resimden 1. Lenovo IdeaPad Y410p Keyboard Replacement, Keyboard: adım 4, 2 resimden 2.
    • Power off your laptop.
    • Use a metal spudger to loosen the frame of the keyboard by running it under the edges of the keyboard as shown.
    • After loosening the keyboard frame, you should be able to gently lift up the keyboard.
    There are two screws underneath the bottom casing, marked specifically with a keyboard icon:
    https://i.imgur.com/Gxuc5E8.jpg
    You HAVE to remove these screws before you start to pry up the keyboard.
    Dragon - Yanıt
  5. Lenovo IdeaPad Y410p Keyboard Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad Y410p Keyboard Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad Y410p Keyboard Replacement: adım 5, 3 resimden 3.
    • Be careful when lifting the keyboard so that you do not damage the ribbon cable connector.
    • Detach the ribbon cables from the latches shown.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nick Torres
580 İtibar
5 adet Kılavuz yazıldı
2 Yorum
Terrible guide - completely fails to point out the two screws that hold the keyboard down underneath the bottom casing. Bent my keyboard thanks to this.
Dragon - Yanıt
Awful guide. Wish I'd seen the other comment before I also ruined my keyboard. Thought it popped out, but there's 2 screws under the bottom case that hold it (remove!) … bent the keyboard frame and ripped the screw tabs off. Was just trying to clean it. Now it needs total replacement.
How is this article reportable?
Nateb - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 1,067
