Ana içeriğe geç
Lenovo IdeaPad Y410p Ram Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Y410p Ram Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Ram Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Y410p Ram Replacement: adım 2, 2 resimden 2.
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Ram Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad Y410p Ram Replacement: adım 3, 2 resimden 2.
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Ram Replacement, Ram: adım 4, 3 resimden 1. Lenovo IdeaPad Y410p Ram Replacement, Ram: adım 4, 3 resimden 2. Lenovo IdeaPad Y410p Ram Replacement, Ram: adım 4, 3 resimden 3.
    • Using the Phillips #0 screwdriver remove the eight 8mm screws that fasten the bottom cover.
    • Lift the bottom cover off using a metal spudger and set it aside.
  5. Lenovo IdeaPad Y410p Ram Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad Y410p Ram Replacement: adım 5, 2 resimden 2.
    • Simultaneously pull apart both clips that are holding the RAM module down.
    • When the RAM module is released carefully pull it out.
  6. Lenovo IdeaPad Y410p Ram Replacement: adım 6, 2 resimden 1. Lenovo IdeaPad Y410p Ram Replacement: adım 6, 2 resimden 2.
    • There is a second ram module under the first one.
    • Repeat Step 5 with lower Ram module.
Sonuç
Nick Torres
580 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 826
