Ana içeriğe geç
Lenovo IdeaPad Y410p Screen Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Y410p Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Screen Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Y410p Screen Replacement: adım 2, 2 resimden 2.
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Screen Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad Y410p Screen Replacement: adım 3, 2 resimden 2.
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Screen Replacement, Screen: adım 4, 2 resimden 1. Lenovo IdeaPad Y410p Screen Replacement, Screen: adım 4, 2 resimden 2.
    • Using the metal spudger, pry the screen cover off from all sides.
    • Carefully lift the screen cover up and outwards.
    • Place the screen cover aside.
  5. Lenovo IdeaPad Y410p Screen Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad Y410p Screen Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad Y410p Screen Replacement: adım 5, 3 resimden 3.
    • Using the Phillips #0 screwdriver, remove the four 8mm screws from each corner of the screen.
    • Carefully lift the screen up and place it face down on the keyboard.
    • A thick cord connects the bottom of the screen to the computer. Do not tug or remove this cord from the computer.
  6. Lenovo IdeaPad Y410p Screen Replacement: adım 6, 2 resimden 1. Lenovo IdeaPad Y410p Screen Replacement: adım 6, 2 resimden 2.
    • Remove the adhesive tape from the small rectangular connector at the bottom of the screen.
    • Carefully pull the wire connector from the screen connector.
    • Remove the screen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nick Torres
580 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 419
