Ana içeriğe geç
Lenovo IdeaPad Y500 Touchpad Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Y500 Touchpad  Replacement, Battery: adım 1, 3 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement, Battery: adım 1, 3 resimden 2. Lenovo IdeaPad Y500 Touchpad  Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the lock on the right side until you hear a click. Once you hear a click , you should see the color red.
  2. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 2, 1 resimden 1.
    • Unlike the first lock, this lock is spring loaded and must be held in place when used.
    • Slide the lock to the left (in the direction of the arrow below the lock) and hold in place.
  3. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 3, 1 resimden 1.
    • Gently pull battery away from the computer while holding open the lock.
  4. Lenovo IdeaPad Y500 Touchpad  Replacement, Keyboard: adım 4, 3 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement, Keyboard: adım 4, 3 resimden 2. Lenovo IdeaPad Y500 Touchpad  Replacement, Keyboard: adım 4, 3 resimden 3.
    • Unlock the battery latch by pulling it up.
    • It should reveal red underneath when it's unlocked.
  5. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 5, 3 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 5, 3 resimden 2. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 5, 3 resimden 3.
    • Push the latch down and then hold in position.
    • Pull the optical drive out.
  6. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 6, 3 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 6, 3 resimden 2. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 6, 3 resimden 3.
    • Remove nine screws with a Phillips #1 screwdriver.
  7. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 7, 3 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 7, 3 resimden 2. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 7, 3 resimden 3.
    • Pull up on the loosened cover to remove.
    • Remove two screws with a Phillips #1 screwdriver.
  8. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 8, 3 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 8, 3 resimden 2. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 8, 3 resimden 3.
    • Pull the tab straight to the left until part releases.
    • Lift up the part to remove completely.
  9. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 9, 3 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 9, 3 resimden 2. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 9, 3 resimden 3.
    • To release the DIMM, pull the tabs on either side away from each other simultaneously.
    • The DIMM will pop out on its own.
  10. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 10, 3 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 10, 3 resimden 2. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 10, 3 resimden 3.
    • To disconnect the Wi-Fi cables, use a spudger to gently push up under them.
    • Wi-Fi cables are delicate.
  11. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 11, 3 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 11, 3 resimden 2. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 11, 3 resimden 3.
    • Using a Phillips #1 screwdriver, remove the two screws.
    • Once screws are out, the card will just pop out.
  12. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 12, 1 resimden 1.
    • Remove three screws using a Phillips #1 screwdriver.
  13. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 13, 3 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 13, 3 resimden 2. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 13, 3 resimden 3.
    • With the laptop upside down, open slightly.
    • To remove the keyboard, push the back of the keyboard forward with your thumb while pulling away from the laptop on the other side.
    • You will not be able to pull the keyboard completely away. The cables are still connected to the laptop.
  14. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 14, 3 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 14, 3 resimden 2. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 14, 3 resimden 3.
    • To release the cables, use the spudger to push both ends on the side of the cable.
    • Gently pull the cables up to disconnect.
  15. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 15, 2 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 15, 2 resimden 2.
    • Pull the keyboard up and away from the laptop to remove it.
  16. Lenovo IdeaPad Y500 Touchpad  Replacement, Touchpad: adım 16, 2 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement, Touchpad: adım 16, 2 resimden 2.
    • Remove a total of 8 screws.
    • Red circles are m2.5 x 10 mm flathead screws.
    • Orange circles m2 x 3mm flathead screws.
    • Yellow circle is m2.5 x 4mm flathead screw.
  17. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 17, 3 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 17, 3 resimden 2. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 17, 3 resimden 3.
    • Flip up black tabs at the ends of each cable.
    • With fingers, gently remove the cables underneath from their ports.
  18. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 18, 3 resimden 1. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 18, 3 resimden 2. Lenovo IdeaPad Y500 Touchpad  Replacement: adım 18, 3 resimden 3.
    • By unlatching the sides and pulling up, remove the top case from the device.
    • Casing is fragile, be careful not to twist when pulling up.
Sonuç
Tatum Hennige
687 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G2, Cardinal Spring 2019 UW Tacoma, Team S1-G2, Cardinal Spring 2019 üyesi
UWT-CARDINAL-S19S1G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 623
