Ana içeriğe geç
Lenovo IdeaPad Y580-2099 Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Y580-2099 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Slide out both locks for the battery, located on the back of the device.
  2. Lenovo IdeaPad Y580-2099 Motherboard Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Y580-2099 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the battery.
  3. Lenovo IdeaPad Y580-2099 Motherboard Replacement, Keyboard: adım 3, 2 resimden 1. Lenovo IdeaPad Y580-2099 Motherboard Replacement, Keyboard: adım 3, 2 resimden 2.
    • Unscrew the 2 screws on the bottom of the device.
    • Slide the back panel out.
  4. Lenovo IdeaPad Y580-2099 Motherboard Replacement: adım 4, 1 resimden 1.
    • Unscrew the 3 "keyboard" detected screws.
  5. Lenovo IdeaPad Y580-2099 Motherboard Replacement: adım 5, 2 resimden 1. Lenovo IdeaPad Y580-2099 Motherboard Replacement: adım 5, 2 resimden 2.
    • Flip the laptop over and open up.
    • Then pry up the whole keyboard using the spudger.
    • Make sure to use a plastic spudger. You could damage the device using anything else.
    • Make sure not to take the frame that goes around the keys off. This part is not removable.
  6. Lenovo IdeaPad Y580-2099 Motherboard Replacement, Motherboard: adım 6, 3 resimden 1. Lenovo IdeaPad Y580-2099 Motherboard Replacement, Motherboard: adım 6, 3 resimden 2. Lenovo IdeaPad Y580-2099 Motherboard Replacement, Motherboard: adım 6, 3 resimden 3.
    • Flip laptop back over and unscrew the disc drive screw.
    • Remove the disc drive.
    • Unscrew all of the screws on the back of the device.
  7. Lenovo IdeaPad Y580-2099 Motherboard Replacement: adım 7, 3 resimden 1. Lenovo IdeaPad Y580-2099 Motherboard Replacement: adım 7, 3 resimden 2. Lenovo IdeaPad Y580-2099 Motherboard Replacement: adım 7, 3 resimden 3.
    • Flip the device over.
    • Unplug the two wires, as shown in the images.
    • Lift up on the keyboard bezel.
    • The bezel should come up easy, if not go back and make sure all screws have been removed.
  8. Lenovo IdeaPad Y580-2099 Motherboard Replacement: adım 8, 2 resimden 1. Lenovo IdeaPad Y580-2099 Motherboard Replacement: adım 8, 2 resimden 2.
    • Unscrew the screws on the motherboard.
    • Disconnect the three connectors the two black and one white.
  9. Lenovo IdeaPad Y580-2099 Motherboard Replacement: adım 9, 1 resimden 1.
    • Carefully lift up the motherboard.
    • Unplug the wires underneath the motherboard.
    • Be careful not to rip the wires underneath the motherboard while lifting it up.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lauren
481 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 1,532
