Ana içeriğe geç
Lenovo IdeaPad Y700-15ACZ Battery Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Y700-15ACZ Battery Replacement, Battery: adım 1, 2 resimden 1. Lenovo IdeaPad Y700-15ACZ Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop upside down so that the bottom is facing up.
    • Using the #0 Phillips screwdriver, unscrew the eleven Phillips #0 screws (two 1.5 mm screws, one 0.3 mm screw, and eight 0.5 mm screws) that attach the cover to the laptop.
  2. Lenovo IdeaPad Y700-15ACZ Battery Replacement: adım 2, 1 resimden 1.
    • After removing the eleven Phillips #0 screws (two 1.5 mm screws, one 0.3 mm screw, and eight 0.5 mm screws), use the Jimmy to pop up the cover and remove it from the laptop.
  3. Lenovo IdeaPad Y700-15ACZ Battery Replacement: adım 3, 2 resimden 1. Lenovo IdeaPad Y700-15ACZ Battery Replacement: adım 3, 2 resimden 2.
    • Find the battery connection above the battery.
    • Unplug the battery from the motherboard.
  4. Lenovo IdeaPad Y700-15ACZ Battery Replacement: adım 4, 3 resimden 1. Lenovo IdeaPad Y700-15ACZ Battery Replacement: adım 4, 3 resimden 2. Lenovo IdeaPad Y700-15ACZ Battery Replacement: adım 4, 3 resimden 3.
    • Unscrew the 0.5 mm screws from battery connected to the motherboard with the #0 Philips screwdriver.
    • Gently lift the battery from the laptop and replace the battery.
Sonuç
Kevin
351 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 6-6, Adachi Fall 2022 CSU Los Angeles, Team 6-6, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S6G6
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 52
Her zaman: 1,039
