Ana içeriğe geç
Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement, Cooling Fan: adım 1, 2 resimden 1. Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement, Cooling Fan: adım 1, 2 resimden 2.
    • Flip your laptop so that the bottom of it is facing you.
    • Use a Phillips #00 screwdriver to remove the following screws from the bottom cover:
    • Eight 5.4 mm screws.
    • One 5.6 mm screws.
    • Two 15.4 mm screws.
    • Remove the back plane.
  2. Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement: adım 2, 2 resimden 1. Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the three 3.9 mm screws.
    • Use a Phillips #00 screwdriver to remove the single 5.6 mm screw between the two fans.
    • This tutorial is describing how to replace both fans, if you need to replace one fan, you don't need to remove both.
  3. Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement: adım 3, 1 resimden 1.
    • To disconnect the cable, pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable. If you can, apply the force to the plastic reinforcement rather than the cable itself.
  4. Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad Y700-15ACZ Cooling Fan Replacement: adım 4, 2 resimden 2.
    • Remove the fan(s) from the laptop after finishing Step 3.
Sonuç
To reassemble your device, follow these instructions in reverse order. To ensure that every component is perfectly aligned and firmly secured, careful attention to detail must be made during the reassembly procedure. Inaccurately following the instructions may cause harm to the device, which might affect its durability and operation. Therefore, it is crucial to carefully follow the instructions provided in order to complete the reassembly in a successful and secure manner.
Bir başkası bu kılavuzu tamamladı.
Antwan Khoury
133 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 3-1, Harley Spring 2023 IUPUI, Team 3-1, Harley Spring 2023 üyesi
IUPUI-HARLEY-S23S3G1
3 Üyeler
3 adet Kılavuz yazıldı
1Rehber Yorum
Now my laptop won't start. And it only shows two light on the bottom. It is not black screen problem. Then what is it, help me plz. It has been 2 hours like this..
Lee DaeHoon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 453
