Ana içeriğe geç
Lenovo IdeaPad Y700-15ACZ Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Y700-15ACZ Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Lenovo IdeaPad Y700-15ACZ Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Flip the laptop upside down so that the bottom is facing up.
    • Using the #0 Phillips screwdriver, unscrew the eleven Phillips #0 screws (two 1.5 mm screws, one 0.3 mm screw, and eight 0.5 mm screws) that attach the cover to the laptop.
  2. Lenovo IdeaPad Y700-15ACZ Motherboard Replacement: adım 2, 1 resimden 1.
    • After removing the eleven Phillips #0 screws (two 1.5 mm screws, one 0.3 mm screw, and eight 0.5 mm screws), use the Jimmy to pop up the cover and remove it from the laptop.
  3. Lenovo IdeaPad Y700-15ACZ Motherboard Replacement: adım 3, 3 resimden 1. Lenovo IdeaPad Y700-15ACZ Motherboard Replacement: adım 3, 3 resimden 2. Lenovo IdeaPad Y700-15ACZ Motherboard Replacement: adım 3, 3 resimden 3.
    • Unscrew the 16 Phillips #0 screws and 1 Philips #00 screw ( 0.5 mm screws, one 1 mm screw) from the motherboard, the fan, and the speaker to remove and replace the motherboard.
Sonuç
Kevin
351 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 6-6, Adachi Fall 2022 CSU Los Angeles, Team 6-6, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S6G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 278
