Ana içeriğe geç
Lenovo IdeaPad Yoga 11S RAM Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Yoga 11S RAM Replacement, Top Assembly: adım 1, 3 resimden 1. Lenovo IdeaPad Yoga 11S RAM Replacement, Top Assembly: adım 1, 3 resimden 2. Lenovo IdeaPad Yoga 11S RAM Replacement, Top Assembly: adım 1, 3 resimden 3.
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
  2. Lenovo IdeaPad Yoga 11S RAM Replacement, Remove Keyboard: adım 2, 1 resimden 1.
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S RAM Replacement: adım 3, 1 resimden 1.
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S RAM Replacement: adım 4, 3 resimden 1. Lenovo IdeaPad Yoga 11S RAM Replacement: adım 4, 3 resimden 2. Lenovo IdeaPad Yoga 11S RAM Replacement: adım 4, 3 resimden 3.
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
  5. Lenovo IdeaPad Yoga 11S RAM Replacement, RAM: adım 5, 3 resimden 1. Lenovo IdeaPad Yoga 11S RAM Replacement, RAM: adım 5, 3 resimden 2. Lenovo IdeaPad Yoga 11S RAM Replacement, RAM: adım 5, 3 resimden 3.
    • Locate the RAM module.
    • Locate the tabs on both sides of the RAM module
    • Spread both tabs outward at the same time in order to release the RAM module.
  6. Lenovo IdeaPad Yoga 11S RAM Replacement: adım 6, 1 resimden 1.
    • Grab the RAM module and carefully pull it out from its position.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Landon Epps
982 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 7-11, Williams Spring 2015 Baylor, Team 7-11, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S7G11
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Excelente… easy and simply.
Iver Antelo - Yanıt
At Step 3. Replace the memory now that it is exposed. You don't have to do steps 4-5, I don't think you have to remove the 10 small screws either.
Just the Philips under the foot tabs and carefully remove the keyboard, pull the tabs back that secure the memory and replace with new memory.
Kyle Brock - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 36
Her zaman: 9,112
