Giriş
Replacing the Wi-Fi card is a semi-invasive repair and should only be attempted if your computer is not recognizing a wireless antenna. This symbol in the hot-bar on the bottom right that normally indicates a wireless connection will appear to be a small box with a wire coming out.
NOTE: It is VERY important to make sure to check that Wi-Fi is NOT DISABLED on your device before attempting this repair, as this may be the problem and a repair attempt will only increase the chances of causing damage.
Neye ihtiyacın var
Remove the ten screws on the back panel of the laptop using the T4 Torx screwdriver.
Remove the back panel from the device.
