Ana içeriğe geç
Lenovo IdeaPad Z570 Charging Port Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Z570 Charging Port Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Charging Port Replacement: adım 2, 1 resimden 1.
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Charging Port Replacement: adım 3, 1 resimden 1.
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Charging Port Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement: adım 4, 2 resimden 2.
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Charging Port Replacement, Disc Drive: adım 5, 1 resimden 1.
    • Place the laptop face down with the battery slot facing away from you.
  6. Lenovo IdeaPad Z570 Charging Port Replacement: adım 6, 2 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement: adım 6, 2 resimden 2.
    • Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
    • These screws cannot be removed from the device.
    • Remove the back panel from the device.
  7. Lenovo IdeaPad Z570 Charging Port Replacement: adım 7, 2 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement: adım 7, 2 resimden 2.
    • Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
  8. Lenovo IdeaPad Z570 Charging Port Replacement: adım 8, 2 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement: adım 8, 2 resimden 2.
    • Gently remove the disc drive from the left hand side of the laptop.
  9. Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: adım 9, 3 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: adım 9, 3 resimden 2. Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: adım 9, 3 resimden 3.
    • Remove the three 12mm screws found near these symbols with a Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Charging Port Replacement: adım 10, 1 resimden 1.
    • Orient the laptop at a 90 degree angle with the keyboard being vertical and the screen horizontal to the surface you are working on.
  11. Lenovo IdeaPad Z570 Charging Port Replacement: adım 11, 2 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement: adım 11, 2 resimden 2.
    • Pry the keyboard off staring from the corner where the “esc”” key is located using an opening tool.
    • Now orient the laptop in the standard position and take off the keyboard.
  12. Lenovo IdeaPad Z570 Charging Port Replacement: adım 12, 3 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement: adım 12, 3 resimden 2. Lenovo IdeaPad Z570 Charging Port Replacement: adım 12, 3 resimden 3.
    • At the terminal block, flip the black switch on the terminal up.
  13. Lenovo IdeaPad Z570 Charging Port Replacement: adım 13, 2 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement: adım 13, 2 resimden 2.
    • Pull the keyboard out from the terminal block.
  14. Lenovo IdeaPad Z570 Charging Port Replacement, Charging Port: adım 14, 1 resimden 1.
    • Place the laptop on the backside with the battery facing away from you.
    • Remove the eleven 7 mm screws located around the edge of the backside of the laptop using the Phillips #0 screwdriver.
  15. Lenovo IdeaPad Z570 Charging Port Replacement: adım 15, 2 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement: adım 15, 2 resimden 2.
    • Remove the two 3 mm screws located in the battery slot using the Phillips #0 screwdriver.
    • Orientate the laptop back to its original position.
  16. Lenovo IdeaPad Z570 Charging Port Replacement: adım 16, 3 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement: adım 16, 3 resimden 2. Lenovo IdeaPad Z570 Charging Port Replacement: adım 16, 3 resimden 3.
    • There are three connection strips similar to the one in guide three.
    • Remove the three connection strips in the same manner as the keyboard replacement guide.
  17. Lenovo IdeaPad Z570 Charging Port Replacement: adım 17, 2 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement: adım 17, 2 resimden 2.
    • Remove the two 7mm screws found on the right side of the silver plating on the laptop using the Phillips #0 screwdriver.
  18. Lenovo IdeaPad Z570 Charging Port Replacement: adım 18, 3 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement: adım 18, 3 resimden 2. Lenovo IdeaPad Z570 Charging Port Replacement: adım 18, 3 resimden 3.
    • Wedge the opening tool between the ethernet jack and the speaker to pry of the front plate of the laptop.
  19. Lenovo IdeaPad Z570 Charging Port Replacement: adım 19, 2 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement: adım 19, 2 resimden 2.
    • Remove the one 7 mm screw located at the top left corner of the laptop near the charging port using the Phillips #0 screwdriver.
  20. Lenovo IdeaPad Z570 Charging Port Replacement: adım 20, 2 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement: adım 20, 2 resimden 2.
    • There are two connection terminals on the upper right hand corner of the fan.
    • Remove the connection terminal marked with a blue stripe.
  21. Lenovo IdeaPad Z570 Charging Port Replacement: adım 21, 3 resimden 1. Lenovo IdeaPad Z570 Charging Port Replacement: adım 21, 3 resimden 2. Lenovo IdeaPad Z570 Charging Port Replacement: adım 21, 3 resimden 3.
    • Lift the metal plate enough to wedge your index finger and thumb to grip the charger port.
    • Remove the charging port from the device.
Sonuç
Mya DeSantos
318 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G6, Botvin Spring 2019 UMass Dartmouth, Team S1-G6, Botvin Spring 2019 üyesi
UMASSD-BOTVIN-S19S1G6
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 35
Her zaman: 1,655
