Ana içeriğe geç
Lenovo IdeaPad Z570 Disc Drive Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Z570 Disc Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Disc Drive Replacement: adım 2, 1 resimden 1.
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Disc Drive Replacement: adım 3, 1 resimden 1.
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Disc Drive Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad Z570 Disc Drive Replacement: adım 4, 2 resimden 2.
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Disc Drive Replacement, Disc Drive: adım 5, 1 resimden 1.
    • Place the laptop face down with the battery slot facing away from you.
  6. Lenovo IdeaPad Z570 Disc Drive Replacement: adım 6, 2 resimden 1. Lenovo IdeaPad Z570 Disc Drive Replacement: adım 6, 2 resimden 2.
    • Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
    • These screws cannot be removed from the device.
    • Remove the back panel from the device.
  7. Lenovo IdeaPad Z570 Disc Drive Replacement: adım 7, 2 resimden 1. Lenovo IdeaPad Z570 Disc Drive Replacement: adım 7, 2 resimden 2.
    • Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
  8. Lenovo IdeaPad Z570 Disc Drive Replacement: adım 8, 2 resimden 1. Lenovo IdeaPad Z570 Disc Drive Replacement: adım 8, 2 resimden 2.
    • Gently remove the disc drive from the left hand side of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Lopes
610 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G6, Botvin Spring 2019 UMass Dartmouth, Team S1-G6, Botvin Spring 2019 üyesi
UMASSD-BOTVIN-S19S1G6
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 699
