Ana içeriğe geç
Lenovo IdeaPad Z570 Screen Replacement
Neye ihtiyacın var
  1. Lenovo IdeaPad Z570 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Screen Replacement: adım 2, 1 resimden 1.
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Screen Replacement: adım 3, 1 resimden 1.
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Screen Replacement: adım 4, 2 resimden 1. Lenovo IdeaPad Z570 Screen Replacement: adım 4, 2 resimden 2.
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Screen Replacement, Screen: adım 5, 1 resimden 1.
    • Open up the laptop with the screen facing you.
  6. Lenovo IdeaPad Z570 Screen Replacement: adım 6, 2 resimden 1. Lenovo IdeaPad Z570 Screen Replacement: adım 6, 2 resimden 2.
    • Remove the two rubber square screw covers located in the left and right lower hand corners of the screen.
  7. Lenovo IdeaPad Z570 Screen Replacement: adım 7, 2 resimden 1. Lenovo IdeaPad Z570 Screen Replacement: adım 7, 2 resimden 2.
    • Unscrew the two 4 mm screws behind the two rubber screw covers using the Phillips #0 screwdriver.
  8. Lenovo IdeaPad Z570 Screen Replacement: adım 8, 2 resimden 1. Lenovo IdeaPad Z570 Screen Replacement: adım 8, 2 resimden 2.
    • Using the opening tool, pry open the plastic screen border, beginning with the upper right hand corner then working your way around.
    • Pry off the screen cover from the device.
  9. Lenovo IdeaPad Z570 Screen Replacement: adım 9, 2 resimden 1. Lenovo IdeaPad Z570 Screen Replacement: adım 9, 2 resimden 2.
    • Remove the two 2 mm screws at the top two corners of the screen using the Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Screen Replacement: adım 10, 2 resimden 1. Lenovo IdeaPad Z570 Screen Replacement: adım 10, 2 resimden 2.
    • Loosen the four 2 mm screws located at the bottom corners of the screen.
    • These screws cannot be removed.
  11. Lenovo IdeaPad Z570 Screen Replacement: adım 11, 3 resimden 1. Lenovo IdeaPad Z570 Screen Replacement: adım 11, 3 resimden 2. Lenovo IdeaPad Z570 Screen Replacement: adım 11, 3 resimden 3.
    • Tilt the screen forward gently.
    • Remove four 3 mm screws on the sides of the brackets holding the screen (two on the left side and two on the right side) using the Phillips #0 screwdriver.
  12. Lenovo IdeaPad Z570 Screen Replacement: adım 12, 1 resimden 1.
    • Lean the LCD screen face-down on the keyboard gently.
  13. Lenovo IdeaPad Z570 Screen Replacement: adım 13, 3 resimden 1. Lenovo IdeaPad Z570 Screen Replacement: adım 13, 3 resimden 2. Lenovo IdeaPad Z570 Screen Replacement: adım 13, 3 resimden 3.
    • Gently remove the adhesive covering surrounding the wires that’s connected to the back of the screen.
    • Disconnect the plug from the connection terminal.
    • Remove the screen completely.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Lopes
610 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G6, Botvin Spring 2019 UMass Dartmouth, Team S1-G6, Botvin Spring 2019 üyesi
UMASSD-BOTVIN-S19S1G6
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 1,042
