Ana içeriğe geç
Lenovo IdeaTab A1000L 7" Display Assembly Replacement
Görüntüleme: 9,2 B
İstatistikleri görüntüle:
Son 24 Saat:
3
Son 7 Gün:
19
Son 30 Gün:
109
Her zaman:
9.179
Yorumlar: 5
5 guide comments.
Go to guide comments
Tamamlandı: 5
5 kişi bu kılavuzu "tamamlandı" olarak işaretledi. Sıradaki sen olacak mısın?
Sık Kullanılanlar: 8
8 kişi bu kılavuzu favorilerine ekledi (ve abone oldu). Sıradaki sen olacak mısın?
Gerekli Süre: 15 - 20 dakika
Zorluk: Orta
If you have any problem with your display screen, follow these steps to remove it and replace it with a new one.
Neye ihtiyacın var
Aletler
    1. Lenovo IdeaTab A1000L 7" Display Assembly Replacement, 7" Display Assembly: adım 1, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Be sure to power off your device before taking it apart.
      • Locate the small tab, marked with the lock symbol on the upper right hand of your IdeaTab above the volume control buttons. Use your fingernail to gently open this tab.
      • Use your Phillips #000 screwdriver and remove the 3.5mm screw and put it aside.
      • There may be a sticker covering the head of the screw. If so, remove the sticker with tweezers and remove the screw.
      FixBot'a Sor
      Yorum Ekle
    2. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 2, 1 resimden 1.
      • Using your blue, plastic opening tool, begin to gently pry the back panel away from the front panel starting at the charging port. Continue prying along the right edge of the back cover.
      • Pry carefully to avoid cracking or snapping the plastic back cover.
      • Work the plastic opening tool around the entire device, to free the remaining plastic clips and remove back cover.
      FixBot'a Sor
      Yorum Ekle
    3. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 3, 1 resimden 1.
      • Locate the volume key on the right hand side of the tablet.
      • Slide the volume key upwards to remove it.
      FixBot'a Sor
      Yorum Ekle
    4. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 4, 2 resimden 1. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 4, 2 resimden 2.
      • Using a Phillips #000 screwdriver remove the 7 silver M1.4 3.5mm screws from the back plate.
      • Next, with the same screwdriver remove the black M1.4 4.1mm screw.
      • Gently remove the back plate from the device.
      FixBot'a Sor
      Yorum Ekle
    5. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 5, 1 resimden 1.
      • Locate the power key on the top right hand side of the tablet.
      • Slide the key upwards to remove it.
      FixBot'a Sor
      Yorum Ekle
    6. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 6, 3 resimden 1. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 6, 3 resimden 2. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 6, 3 resimden 3.
      • Use the plastic opening tool to disconnect the battery wires from the system board. Slide your opening tool under the white plastic piece and gently pull up.
      • Use the plastic opening tool to loosen the battery from the device by lifting up on the battery on all sides. This will detach the battery from the adhesive.
      FixBot'a Sor
      Yorum Ekle
    7. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 7, 1 resimden 1.
      • Locate the volume button mechanism.
      • The volume button mechanism is called an FPC, it is adhered to the device frame. Remove it by prying it off using a tweezer or plastic opening tool.
      • Remove the FPC to the left of the volume button mechanism the same way.
      FixBot'a Sor
      Yorum Ekle
    8. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 8, 1 resimden 1.
      • Locate the power button mechanism.
      • Remove the power button mechanism by prying it off using a tweezer or plastic opening tool.
      FixBot'a Sor
      Yorum Ekle
    9. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 9, 1 resimden 1.
      • Remove the circular motor unit by gently pulling up on it using a tweezer.
      FixBot'a Sor
      Yorum Ekle
    10. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 10, 3 resimden 1. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 10, 3 resimden 2. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 10, 3 resimden 3.
      • Locate the component with a QR code printed on it.
      • To disconnect this component you must first detach it from the white connector.
      • To detach it from the connector, use a tweezer to gently rotate the black piece 90 degrees so it is pointing up.
      • The white connector may have a yellow mylar sticker over it. Peel off the sticker and continue.
      • Once the black piece is pointing up the orange wires can be removed from the connectors. Using a tweezer pull the orange wires horizontally outwards from the white connector.
      FixBot'a Sor
      Yorum Ekle
    11. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 11, 2 resimden 1. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 11, 2 resimden 2.
      • Locate the orange cable to the right of the battery tray.
      • To disconnect this component you must first detach it from the white connector. Using a tweezer, pry the black piece upwards and rotate it 90 degrees so it points up.
      • There may be a yellow mylar sticker onto of the white connector. Peel off the sticker and continue.
      • Once the black piece is pointing up the orange wires can be removed from the connectors. Using a tweezer pull the orange wire horizontally outwards from the white connector.
      FixBot'a Sor
      Yorum Ekle
    12. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 12, 1 resimden 1.
      • Using a #000 Phillips screwdriver, remove the two M1.4 3.5mm screws from the system board and set them aside.
      FixBot'a Sor
      Yorum Ekle
    13. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 13, 1 resimden 1.
      • Locate the audio assembly near the top-right of the device.
      • Remove the audio assembly by inserting the tweezers in the circular hole in the black plastic box and pulling upwards.
      FixBot'a Sor
      Yorum Ekle
    14. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 14, 2 resimden 1. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 14, 2 resimden 2.
      • Locate the microphone at the bottom of the device.
      • Remove the microphone from its cavity by using tweezers to pull up the black and red cords and microphone with them.
      FixBot'a Sor
      Yorum Ekle
    15. Lenovo IdeaTab A1000L 7" Display Assembly Replacement: adım 15, 1 resimden 1.
      • The system board is now completely free from the device. Carefully lift the system board up off the device and place on a padded surface.
      • The screen display unit is now ready to be replaced.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Finley Marbury
410 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-21, Regan Spring 2014 Cal Poly, Team 7-21, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G21
4 Üyeler
72 adet Kılavuz yazıldı
5Kılavuz Yorumları
This dose NOT tell you how to replace the screen. Just how to take the board out and battery, Useless.
Lucky Bob - Yanıt Paylaş
Bob, it looks like the display assembly should be the last remaining component at the end of the guide—is that not correct? If you are looking to replace an individual display component, such as the digitizer glass, then yes that will require a different approach.
Jeff Suovanen - Yanıt Paylaş
I too wonder how the LCD display and digitizer --machine has both come out. Do you pry them out from the front or back. The article stops at the wrong place. How do the screens actually come out.
Arnie Rosen - Yanıt Paylaş
It appears that you have to turn over the unit and with a heat gun go around the edges and separate the digitizerscreen from the LCD. I guess they are two separate screens.. I am hoping the person who wrote this article will continue and show how this is done.
tienen el diagrama?
cesarbarrionuevo9 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 109
Her zaman: 9,179
