Ana içeriğe geç
Lenovo IdeaTab A1000L Battery Replacement
Neye ihtiyacın var
  1. Lenovo IdeaTab A1000L Battery Replacement, Battery: adım 1, 3 resimden 1. Lenovo IdeaTab A1000L Battery Replacement, Battery: adım 1, 3 resimden 2. Lenovo IdeaTab A1000L Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Be sure to power off your device before taking it apart.
    • Locate the small tab, marked with the lock symbol on the upper right hand of your IdeaTab above the volume control buttons. Use your fingernail to gently loosen this tab.
    • Use your Phillips #000 screwdriver and remove the 3.5mm screw and put it aside.
    • Using your blue, plastic opening tool, begin to gently pry the back panel away from the front panel starting by where the screw was.
  2. Lenovo IdeaTab A1000L Battery Replacement: adım 2, 3 resimden 1. Lenovo IdeaTab A1000L Battery Replacement: adım 2, 3 resimden 2. Lenovo IdeaTab A1000L Battery Replacement: adım 2, 3 resimden 3.
    • Locate the black back plate, above the battery.
    • Using a Phillips #000 screwdriver remove the 7 silver 3.5mm screws from the back plate.
    • Next, with the same screwdriver, remove the black 4.1mm screw.
    • Gently remove the back plate from the device.
  3. Lenovo IdeaTab A1000L Battery Replacement: adım 3, 3 resimden 1. Lenovo IdeaTab A1000L Battery Replacement: adım 3, 3 resimden 2. Lenovo IdeaTab A1000L Battery Replacement: adım 3, 3 resimden 3.
    • Use the plastic opening tool to disconnect the battery wires from the system board. Slide your opening tool under the white plastic piece and pry it up.
    • Again, use the plastic opening tool to loosen the battery from the device by lifting up on the battery on all sides. This will detach the battery from the adhesive.
    • Gently place the battery aside.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Peter Newell
627 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-21, Regan Spring 2014 Cal Poly, Team 7-21, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G21
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 21
Her zaman: 23,061
