Giriş
Use this guide to replace the battery.
Parçalar
Hiçbir parça belirtilmedi.
Look at the back of the tablet and locate the speakers on top of the rear cover.
There is a smaller indentation in the plastic cover that runs across the top of the device.
Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
9 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
If there is an SD Micro memory card installed, REMOVE IT!, before the back cover. Otherwise, the card reader/writer will be damaged.
