Ana içeriğe geç
Lenovo IdeaTab A2109 Battery Replacement
Neye ihtiyacın var
  1. Lenovo IdeaTab A2109 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
    I just want to find out if my sd card is stuck inside how do I remove it without damaging the tablet.
    Tom Mukotora - Yanıt
  2. Lenovo IdeaTab A2109 Battery Replacement: adım 2, 2 resimden 1. Lenovo IdeaTab A2109 Battery Replacement: adım 2, 2 resimden 2.
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 Battery Replacement: adım 3, 2 resimden 1. Lenovo IdeaTab A2109 Battery Replacement: adım 3, 2 resimden 2.
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 Battery Replacement: adım 4, 2 resimden 1. Lenovo IdeaTab A2109 Battery Replacement: adım 4, 2 resimden 2.
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 Battery Replacement: adım 5, 2 resimden 1. Lenovo IdeaTab A2109 Battery Replacement: adım 5, 2 resimden 2.
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
    Fantastic advice. After being told by Lenovo I needed to shell out £110 for a new mobo when it just had a charging socket issue I took it upon myself to see if I could fix it. This website helped take it apart and I found that the charging socket is just a micro daughter-board.
    If you have a problem with charging then go to http://www.replacebase.co.uk and search for Lenovo A2109A. They have all the parts.
    I replaced the daughter board and battery for about £10 incl del. Parts arrived yesterday and I have fitted. Works a treat. Not sure what amazes me the most, the low cost of the parts and excellent service by replacebase or the fact Lenovo tried to rip me off.
    These instructions are spot on.
    Well done
    Goon'
    Andy Blunn - Yanıt
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Kyle
581 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-19, Regan Spring 2014 Cal Poly, Team 7-19, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G19
4 Üyeler
15 adet Kılavuz yazıldı
Bir Yorum
If there is an SD Micro memory card installed, REMOVE IT!, before the back cover. Otherwise, the card reader/writer will be damaged.
FilAm Harley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 8,265
