Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace the battery.
Neye ihtiyacın var
Look at the back of the tablet and locate the speakers on top of the rear cover.
There is a smaller indentation in the plastic cover that runs across the top of the device.
Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
Pry open cover using a plastic opening tool.
Leave plastic opening tool in place to maintain the separation.
It may take a little force to separate from the front face of the device
Slide the plastic opening tool to one corner.
Place another plastic opening tool into the gap and slide it to the opposite corner.
Pull the rear cover up and back to separate it from front face of the device.
9 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
If there is an SD Micro memory card installed, REMOVE IT!, before the back cover. Otherwise, the card reader/writer will be damaged.
