Ana içeriğe geç
Lenovo IdeaTab A2109 Digital Board Replacement
Neye ihtiyacın var
  1. Lenovo IdeaTab A2109 Digital Board Replacement, Digital Board: adım 1, 1 resimden 1.
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller plastic cover that runs across the top of the device.
    • Wedge the blue opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 Digital Board Replacement: adım 2, 2 resimden 1. Lenovo IdeaTab A2109 Digital Board Replacement: adım 2, 2 resimden 2.
    • Remove the following two screws:
    • M3.0 x 3.0 mm #00 phillips screws (black)
  3. Lenovo IdeaTab A2109 Digital Board Replacement: adım 3, 3 resimden 1. Lenovo IdeaTab A2109 Digital Board Replacement: adım 3, 3 resimden 2. Lenovo IdeaTab A2109 Digital Board Replacement: adım 3, 3 resimden 3.
    • Once it is unscrewed, remove the rear cover
    • This may take a little force to get off but with enough force it should pop right off
    • Use a blue opening tool to pry it open
    • Slide the tool to one corner then grab another tool and slide it to the opposite corner
    • Pull the cover up and it will come off
  4. Lenovo IdeaTab A2109 Digital Board Replacement: adım 4, 2 resimden 1. Lenovo IdeaTab A2109 Digital Board Replacement: adım 4, 2 resimden 2.
    • Use the tweezer tool to flip up the three small plastic locks attached to the digital board.
    • Then, slide newly exposed ribbons out.
  5. Lenovo IdeaTab A2109 Digital Board Replacement: adım 5, 2 resimden 1. Lenovo IdeaTab A2109 Digital Board Replacement: adım 5, 2 resimden 2.
    • M5.3 x 1.75 mm #00 phillips screws (silver)
  6. Lenovo IdeaTab A2109 Digital Board Replacement: adım 6, 1 resimden 1.
    • Once it is unscrewed, use the tweezer tool to pull the digital board straight out.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Brian
565 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-19, Regan Spring 2014 Cal Poly, Team 7-19, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G19
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 3,116
