Ana içeriğe geç
Lenovo IdeaTab A2109 IO Board Replacement
Neye ihtiyacın var
  1. Lenovo IdeaTab A2109 IO Board Replacement, Battery: adım 1, 1 resimden 1.
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
    I just want to find out if my sd card is stuck inside how do I remove it without damaging the tablet.
    Tom Mukotora - Yanıt
  2. Lenovo IdeaTab A2109 IO Board Replacement: adım 2, 2 resimden 1. Lenovo IdeaTab A2109 IO Board Replacement: adım 2, 2 resimden 2.
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 IO Board Replacement: adım 3, 2 resimden 1. Lenovo IdeaTab A2109 IO Board Replacement: adım 3, 2 resimden 2.
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 IO Board Replacement: adım 4, 2 resimden 1. Lenovo IdeaTab A2109 IO Board Replacement: adım 4, 2 resimden 2.
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 IO Board Replacement: adım 5, 2 resimden 1. Lenovo IdeaTab A2109 IO Board Replacement: adım 5, 2 resimden 2.
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
    Fantastic advice. After being told by Lenovo I needed to shell out £110 for a new mobo when it just had a charging socket issue I took it upon myself to see if I could fix it. This website helped take it apart and I found that the charging socket is just a micro daughter-board.
    If you have a problem with charging then go to http://www.replacebase.co.uk and search for Lenovo A2109A. They have all the parts.
    I replaced the daughter board and battery for about £10 incl del. Parts arrived yesterday and I have fitted. Works a treat. Not sure what amazes me the most, the low cost of the parts and excellent service by replacebase or the fact Lenovo tried to rip me off.
    These instructions are spot on.
    Well done
    Goon'
    Andy Blunn - Yanıt
  6. Lenovo IdeaTab A2109 IO Board Replacement, System Board: adım 6, 3 resimden 1. Lenovo IdeaTab A2109 IO Board Replacement, System Board: adım 6, 3 resimden 2. Lenovo IdeaTab A2109 IO Board Replacement, System Board: adım 6, 3 resimden 3.
    • Remove three silver 1.8 mm Phillips #00 screws.
    You can skip step 8 and step 10, leave these connectors in place (just remove the speaker connector in step 9) lift board enough to remove I/O board and leave most connectors in place.
    green1eng - Yanıt
  7. Lenovo IdeaTab A2109 IO Board Replacement: adım 7, 3 resimden 1. Lenovo IdeaTab A2109 IO Board Replacement: adım 7, 3 resimden 2. Lenovo IdeaTab A2109 IO Board Replacement: adım 7, 3 resimden 3.
    • Use tweezers to flip up the small black plastic locks on all four connections.
    • Carefully remove each of the exposed ribbons.
  8. Lenovo IdeaTab A2109 IO Board Replacement: adım 8, 2 resimden 1. Lenovo IdeaTab A2109 IO Board Replacement: adım 8, 2 resimden 2.
    • Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing.
  9. Lenovo IdeaTab A2109 IO Board Replacement: adım 9, 2 resimden 1. Lenovo IdeaTab A2109 IO Board Replacement: adım 9, 2 resimden 2.
    • Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector.
  10. Lenovo IdeaTab A2109 IO Board Replacement: adım 10, 3 resimden 1. Lenovo IdeaTab A2109 IO Board Replacement: adım 10, 3 resimden 2. Lenovo IdeaTab A2109 IO Board Replacement: adım 10, 3 resimden 3.
    • Disconnect the HDMI connection with the system board
    • Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free.
    • Slide out the system board from its housing tab on the upper right corner.
    • Pull the board slowly away from the tab, and it will pop out.
  11. Lenovo IdeaTab A2109 IO Board Replacement, IO Board: adım 11, 2 resimden 1. Lenovo IdeaTab A2109 IO Board Replacement, IO Board: adım 11, 2 resimden 2.
    • Remove the following two screws:
    • M 5.3 x 1.75 mm #00 phillips screws (silver)
  12. Lenovo IdeaTab A2109 IO Board Replacement: adım 12, 1 resimden 1.
    • Once the screws are out, use the tweezers to pull the board straight out.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Brian
565 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-19, Regan Spring 2014 Cal Poly, Team 7-19, Regan Spring 2014 üyesi
CPSU-REGAN-S14S7G19
4 Üyeler
15 adet Kılavuz yazıldı
6 Yorum
Great guide but make sure you REMOVE THE AUX SD CARD FIRST if installed or you will break the card and or card slot.
Other than that, no problems. I got the io board for $26 and I put it in for free.
James Bush - Yanıt
I need an io board for cheap... I might have to make a guide on how to attempt to repair io card without proper tools and a filed down soldering iron tip
Ember Leona - Yanıt
Thank you this was helpful. I think I fixed my screen flickers the LCD ribbon is under the battery and the ribbon from the volume board on the right I think that's related to the screen rotation lock. Those needed to be flipped up and reseated. Thanks
Ember Leona - Yanıt
Thanks Very much
the guide is very clear
i have done the job successfully
omimh - Yanıt
Excelente guía. Muchas gracias.
Larry Pacheco - Yanıt
You don't have to remove the 4 connectors in step 8 or the camera attachment in step 10, remove only the speaker connector in step nine and just lift the system board enough to unplug it from the I/O board, then put new I/O board in place and press main board down to it. Be careful when snapping the large back cover in place, I broke the plastic where one of the two small retainer screws go. Pretty easy repair overall.
green1eng - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 4,910
