Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace the speakers.
Neye ihtiyacın var
Look at the back of the tablet and locate the speakers on top of the rear cover.
There is a smaller indentation in the plastic cover that runs across the top of the device.
Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
Remove two black 3mm Phillips #00 screws.
Remove three silver 1.8 mm Phillips #00 screws.
Disconnect the HDMI connection with the system board
Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free.
Slide out the system board from its housing tab on the upper right corner.
Pull the board slowly away from the tab, and it will pop out.
Remove the following two screws:
M 5.3 x 1.75 mm #00 phillips screws (silver)
Use the tweezer tool to flip up the three small plastic locks attached to the digital board.
Then, slide newly exposed ribbons out.
