Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace the system board
Neye ihtiyacın var
Look at the back of the tablet and locate the speakers on top of the rear cover.
There is a smaller indentation in the plastic cover that runs across the top of the device.
Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
Remove the following five screws:
Two M 3.0 x 3.0 mm #00 phillips screws (black)
Three M 5.3 x 1.75 mm #00 phillips screws (silver)
Disconnect the HDMI connection with the system board
Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free
Slide out the system board from its housing tab on the upper right corner
Pull the board slowly away from the tab, and it will pop out.
4 farklı kişi bu kılavuzu tamamladı.
