Ana içeriğe geç
Giriş
This guide will help you remove and replace the camera on a Lenovo IdeaTab S2109A-F. If the camera's image on your Lenovo IdeaTab S2109A-F is distorted or cracked, then this guide is for you. Before you begin, please be sure to power off the camera's battery and review the battery replacement guide. There will be many screws that need to be removed in this process. Please be mindful of them and keep track of them as you complete these steps.
Note: It is important to use a gentle hand while making this replacement to avoid causing any damage to the tablet.
Parçalar
Hiçbir parça belirtilmedi.
  1. Lenovo IdeaTab S2109A-F Camera Replacement, Battery: adım 1, 2 resimden 1. Lenovo IdeaTab S2109A-F Camera Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Camera Replacement: adım 2, 2 resimden 1. Lenovo IdeaTab S2109A-F Camera Replacement: adım 2, 2 resimden 2.
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Camera Replacement: adım 3, 1 resimden 1.
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
  4. Lenovo IdeaTab S2109A-F Camera Replacement, Removing the Camera Housing: adım 4, 3 resimden 1. Lenovo IdeaTab S2109A-F Camera Replacement, Removing the Camera Housing: adım 4, 3 resimden 2. Lenovo IdeaTab S2109A-F Camera Replacement, Removing the Camera Housing: adım 4, 3 resimden 3.
    • Remove the two 4 mm screws from the right side of the housing with the Phillips #00 screwdriver.
  5. Lenovo IdeaTab S2109A-F Camera Replacement, Unscrewing the system board: adım 5, 2 resimden 1. Lenovo IdeaTab S2109A-F Camera Replacement, Unscrewing the system board: adım 5, 2 resimden 2.
    • Locate the long, L-shaped system board.
    • Copper runs most of this length.
    • Remove the ten 2 mm screws securing the system board with a Phillips #00 screwdriver.
  6. Lenovo IdeaTab S2109A-F Camera Replacement, Disconnecting the system board: adım 6, 1 resimden 1.
    • Flip the central latch with a large opening tool to expose a gold connector.
    • Gently pull the gold connector using the latch.
  7. Lenovo IdeaTab S2109A-F Camera Replacement, Moving the System board: adım 7, 2 resimden 1. Lenovo IdeaTab S2109A-F Camera Replacement, Moving the System board: adım 7, 2 resimden 2.
    • Pull up the L-shaped board to disconnect the two connectors at the top and bottom of the board.
  8. Lenovo IdeaTab S2109A-F Camera Replacement, Disconnecting the camera: adım 8, 2 resimden 1. Lenovo IdeaTab S2109A-F Camera Replacement, Disconnecting the camera: adım 8, 2 resimden 2.
    • Grab the camera connection with your index finger thumb.
    • Disconnect the camera by gently pulling on this wire.
Sonuç
To reassemble this device, follow these instructions in reverse order.
Timothy
301 İtibar
3 adet Kılavuz yazıldı
USF Tampa, Team 17-3, Watkins Winter 2015 USF Tampa, Team 17-3, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 272
