Ana içeriğe geç
Lenovo IdeaTab S2109A-F I/O Panel Replacement
  1. Lenovo IdeaTab S2109A-F I/O Panel Replacement, Battery: adım 1, 2 resimden 1. Lenovo IdeaTab S2109A-F I/O Panel Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 2, 2 resimden 1. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 2, 2 resimden 2.
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 3, 1 resimden 1.
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
  4. Lenovo IdeaTab S2109A-F I/O Panel Replacement, Speaker: adım 4, 2 resimden 1. Lenovo IdeaTab S2109A-F I/O Panel Replacement, Speaker: adım 4, 2 resimden 2.
    • Remove the ten 2 mm black screws from the edges of the system board with a Phillips #00 screwdriver.
  5. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 5, 1 resimden 1.
    • Disconnect the gold connector by lifting the latch with the plastic opening tool.
  6. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 6, 2 resimden 1. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 6, 2 resimden 2.
    • Pull up on the L-shaped board.
    • The bottom and top connection points should disconnect.
  7. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 7, 2 resimden 1. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 7, 2 resimden 2.
    • Remove the seven 2 mm black screws connecting the speakers using the Phillips #00 screwdriver.
  8. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 8, 3 resimden 1. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 8, 3 resimden 2. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 8, 3 resimden 3.
    • Lift the disconnected speakers from their resting position.
    • Grab the red and black cable with your index finger and thumb.
  9. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 9, 1 resimden 1.
    • Pull up on the connection to disconnect the speakers.
  10. Lenovo IdeaTab S2109A-F I/O Panel Replacement, I/O Panel: adım 10, 2 resimden 1. Lenovo IdeaTab S2109A-F I/O Panel Replacement, I/O Panel: adım 10, 2 resimden 2.
    • Remove the two 2 mm screws that are located at the top of the panel using the Phillips #00 screwdriver.
  11. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 11, 2 resimden 1. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 11, 2 resimden 2.
    • Remove the single 2 mm screw on the front of the panel using a Torx T4 screwdriver.
  12. Lenovo IdeaTab S2109A-F I/O Panel Replacement: adım 12, 1 resimden 1.
    • Lift up on the I/O panel to remove it from the device.
Sonuç
To reassemble your device, follow these instructions in reverse order, starting with placing the panel back into its designated spot and inserting each screw. Begin with the 2mm Torx T-4 screw, then insert the two 2mm PH00 screws according to the instructions.
Timothy
301 İtibar
3 adet Kılavuz yazıldı
USF Tampa, Team 17-3, Watkins Winter 2015 USF Tampa, Team 17-3, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 429
