Ana içeriğe geç
Lenovo IdeaTab S2109A-F Speaker Replacement
  1. Lenovo IdeaTab S2109A-F Speaker Replacement, Battery: adım 1, 2 resimden 1. Lenovo IdeaTab S2109A-F Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Speaker Replacement: adım 2, 2 resimden 1. Lenovo IdeaTab S2109A-F Speaker Replacement: adım 2, 2 resimden 2.
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Speaker Replacement: adım 3, 1 resimden 1.
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
  4. Lenovo IdeaTab S2109A-F Speaker Replacement, Speaker: adım 4, 2 resimden 1. Lenovo IdeaTab S2109A-F Speaker Replacement, Speaker: adım 4, 2 resimden 2.
    • Remove the ten 2 mm black screws from the edges of the system board with a Phillips #00 screwdriver.
  5. Lenovo IdeaTab S2109A-F Speaker Replacement: adım 5, 1 resimden 1.
    • Disconnect the gold connector by lifting the latch with the plastic opening tool.
  6. Lenovo IdeaTab S2109A-F Speaker Replacement: adım 6, 2 resimden 1. Lenovo IdeaTab S2109A-F Speaker Replacement: adım 6, 2 resimden 2.
    • Pull up on the L-shaped board.
    • The bottom and top connection points should disconnect.
  7. Lenovo IdeaTab S2109A-F Speaker Replacement: adım 7, 2 resimden 1. Lenovo IdeaTab S2109A-F Speaker Replacement: adım 7, 2 resimden 2.
    • Remove the seven 2 mm black screws connecting the speakers using the Phillips #00 screwdriver.
  8. Lenovo IdeaTab S2109A-F Speaker Replacement: adım 8, 3 resimden 1. Lenovo IdeaTab S2109A-F Speaker Replacement: adım 8, 3 resimden 2. Lenovo IdeaTab S2109A-F Speaker Replacement: adım 8, 3 resimden 3.
    • Lift the disconnected speakers from their resting position.
    • Grab the red and black cable with your index finger and thumb.
  9. Lenovo IdeaTab S2109A-F Speaker Replacement: adım 9, 1 resimden 1.
    • Pull up on the connection to disconnect the speakers.
Sonuç
Caelen
228 İtibar
2 adet Kılavuz yazıldı
USF Tampa, Team 17-3, Watkins Winter 2015 USF Tampa, Team 17-3, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 406
