Ana içeriğe geç
Lenovo Ideapad 110S-11IBR Speaker Replacement
Neye ihtiyacın var
  1. Lenovo Ideapad 110S-11IBR Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Speaker Replacement: adım 2, 2 resimden 1. Lenovo Ideapad 110S-11IBR Speaker Replacement: adım 2, 2 resimden 2.
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Speaker Replacement: adım 3, 2 resimden 1. Lenovo Ideapad 110S-11IBR Speaker Replacement: adım 3, 2 resimden 2.
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Speaker Replacement: adım 5, 2 resimden 1. Lenovo Ideapad 110S-11IBR Speaker Replacement: adım 5, 2 resimden 2.
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Speaker Replacement, Speaker: adım 6, 1 resimden 1.
    • Use your fingers to gently remove the speaker connector from its socket.
  7. Lenovo Ideapad 110S-11IBR Speaker Replacement: adım 7, 2 resimden 1. Lenovo Ideapad 110S-11IBR Speaker Replacement: adım 7, 2 resimden 2.
    • Unscrew the four 4mm Phillips screws.
  8. Lenovo Ideapad 110S-11IBR Speaker Replacement: adım 8, 1 resimden 1.
    • Pull the right speaker carefully under the ribbon cable.
  9. Lenovo Ideapad 110S-11IBR Speaker Replacement: adım 9, 1 resimden 1.
    • Lift the the left speaker to finish.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 687
