Giriş
This guide will assist you in removing and replacing the touchpad for the Lenovo Ideapad 120s-14IAP. The touch pad is a common issue with this model, and will fix problems with a mouse pointer that will not move or becomes jumpy on the screen.
Neye ihtiyacın var
Orient the laptop so the top is laying flat on your work surface.
Remove ten 1.5mm Torx T5 screws from the back of the laptop.
Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
Using a spudger, disconnect the keyboard ribbon cable from the motherboard.
Pull on the plastic film to remove the display connection cable.
Remove five 2.5 mm Phillips #0 screws from around the battery.
Lift the battery out of the laptop.
Bir başkası bu kılavuzu tamamladı.
