Giriş
A comprehensive how-to guide on replacing the motherboard in a Lenovo Ideapad 120s-14IAP. The motherboard replacement will fix most operational issues with your laptop. If possible, reduce the amount of contact with components of the motherboard during installation.
Neye ihtiyacın var
Orient the laptop so the top is laying flat on your work surface.
Remove ten 1.5mm Torx T5 screws from the back of the laptop.
Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
Using a spudger, disconnect the keyboard ribbon cable from the motherboard.
Pull on the plastic film to remove the display connection cable.
4 farklı kişi bu kılavuzu tamamladı.
